My computer basically just died.. I was gone for the night to come home to my computer being moved across the room. Basically i'm in the process of moving & my mother decided to move my computer to the other side of the room so she can clean. Well i figured it was no big deal, i turned on my computer sat there for a few, then BAM! it restarted.. booted back to windows then restarted again.. then the third time i didn't even load windows before rebooting. So i shut it down, took of the case to make sure she didn't jimmy anything lose.... still no go.. rebooted.
So i tried a second power supply from my older computer that my little sister is using (power supply is fairly new), thinking it would make a difference. it didn't even boot, the fans in the case came on etc.. but the monitor stayed black (didn't hear the usual beep when starting up). After testing her power supply & hooking up the old one, the old one didn't work... So now i'm stuck with a computer that won't even power on at all.. D=
anyone have any ideas what it could be or what i could do to fix it?
spec:
Window XP pro sp2
amd athlon xp 1.4ghz
pc3200 512mbx2 ram
ati x700pro
um any questions & suggestions are welcome! :>
spec:
Window XP pro sp2
pc3200 512mbx2 ram
ati x700pro
