Hey guys, I've been having an issue with my rig recently and was wondering if anyone would have a few thoughts with what's wrong. It's pretty odd.
My rig consists of a:
GA-P35-DS3L
Mushkin KPS DDR2 800 (3GB)
Q6600
eVGA 8800GT
Mastercooler 850W PSU
When I originally built the computer, I used to have some minor problems getting it up and running. This consisted of booting off one stick of RAM, fixing the memory voltages, and booting off all of them. This would lead to the normal boot of:
Power on GPU fan, shut down, power on CPU fan.
This would lead to a successful POST. Recently however, I had issues getting it to post. I figured my RAM might be bad, tried a low voltage Kingston Value stick to see if I could get it back up. It only allows it to POST under tons of power offs/ons/bios battery pulls etc. Once it posts though, THAT stick of ram will continue to work assuming the PC doesn't power down during post. Otherwise I can run a Windows reboot and have it boot back up. Going into bios and fixing the voltage, then switching to the other ram doesn't work. Resetting bios doesn't allow the Kingston to boot back up without trying powering on and off/playing with the bios battery. There is no consistency for when it finally decides to boot, it just does.
So, this leads me to a few questions and theories. I believe the sticks of RAM are probably okay. I'm wondering what are the odds that my PSU could be behind this due to the power cycling sometimes fixing it . . . or do you think it's entirely the motherboard?
Any help is greatly appreciated.
GA-P35-DS3L
Q6600
eVGA 8800GT
