Problem post ovf crater
defuseme2k
So I had an OVF import go south, my laptop here at work decided to be stupid while letting this thing run... so long story short my connection dropped and the import busted.
Not that big of a deal, except I cannot delete the folder that it was importing to. There is one file in there... a -flat.vmdk which reports as being busy when trying to delete from the command line. The thing is, I run a vmkfstools -D and get the UUID of the owner out of the vmkernel log... well, it doesn't match ANY of my host's UUIDs (pumped from esxcfg-info) ... wtf! I've never seen that? I have not yet bounced the hosts or restarted agents. You gotta realize that is a nightmare at this scale, so I really need to track it down.
Any ideas, especially YOU lopoetve?
I can't take the credit alone, but this is sorted out. I'm in an oddball situation where calling VMware for support isn't an option and the vendor who provides it is a joke. SO I'm left to my own vices. First I had to troll a ton of logs and finally figured out which host the ovf import was working its way through. Then a simple restart of vpxa fixed it. I had some Linux gurus around here helping me, but ultimately I figured it out. They deserve some kind of a shout out for spending so much time on it with me :).
*sigh* I still don't get why the UUID when I ran vmkfstools -D didn't match? Is this because it was vpxa instead of hostd? Anyone know?
Local UUID. What were you checking vmkfstools -D against, anyway? IT should be vmkernel ID, which is found with: esxcfg-info.
There was a -flat.vmdk I couldn't delete, I was running it against that trying to figure out which host was owning. And yes, that is what i'm saying. I ran it vmkfstools -D against it and then ran esxcfg-info. None of the hosts UUIDs matched. That is why I'm asking, because the ovf import seems to work a bit oddly anyway; I was curious if it was being imported in a way where the UUID wouldn't match.
Well, it'll probably have been the "uuid" of the host sending it data, through VPXA, or a local lock which is relatively nonsensical in terms of translating.
