problem playing ps2 on a pvr 150
Max-Powers
just got this the other day. tried playing ps2 on it and there is like a 5 sec delay. any way to get rid of this? anyone else play ps2 on thier pvr 150?
win2k
athlon xp 2000
geforce fx 5600
Nope, no way to get rid of it, it's the hardware encoding that does it.
=( so i cant play my consol on it? think i can still watch movies using the ps2?
actually, I think there is a registry hack, but I don't remeber. either way, it is not the best solution. You should be able to watch the movies ok, but it would look better if you just had a DVDrom in the PC.
The pvr150 is gonna re-mpeg the dvd anyway, so it wont look as good as the original. The best solution is to get something like a
prolink xcapture @ newegg
for about $30. It just does svideo/composite, you run the sound to your soundcard input. Im using it for ps2/xbox right now. I havent tried the composite on it, but on my last analog card, svideo was REQUIRED to get a non-crap looking picture.
You will also want to use dscaler with that card for its fantastic deinterlacing / picture cleaning up. (dscaler.com).
it coexists with my pvr2usb hauppauge card. the xcapture software doesnt work right, but im just using dscaler anyway.
djskankho said:
What software are you using to view it? Just wondering...
Me too, Dscaler has been shown to by-pass the MPEG encoding and display a realtime live video so go try that.
yes, i've heard wintv can do the same as long as you don't hit record.
The card atuomatically takes the input stream and encodes it from raw video feed to Mpeg2 data. That is the same compression scheme used in SVCD's and DVD's, albeit at a different resolution. This obviously takes time. The card has an encoder as to avoid stressing the CPU. However, in your case you do not want the video stream encoded, as doing so would serve no purpose unless you are making a video of you playing games.
As was said before, Dscaler should bypass this. IMO, it is one of the best programs for basic TV tuner function.
thank you. dscaler works great. even fixes my problem about watching tv on my 2ndary moniter. uses alot of cpu usage, and does some wierd stuff, but its okey.
Yep DScaler works just fine. I also did the registry hack but that did not really help as much as DScaler.
