problem overclocking - e6400 629B, can it go higher than 3.2?
bcracer220
hello
i have an e6400 with a 629B stepping. it runs fine at 3.2 ghz with only 1.33 to 1.34 volts (after the vdroop). i have a p5b deluxe wifi and im running it under a big typhoon and i cant get past 3.2 ghz, it fails orthos small ffts test within 10 minutes. no matter what the voltage. can these chips go higher than 3.2? or am i doing something wrong? anyone else have an e6400 629B?
my goal is to hit 3.6, please help!
thanks
i have crucial ballistix 8500 and im running them at 800mhz and cas 4, and the fsb is at 401 (multi of 8)
I have an E6400, which runs stock vcore at 3.2GHz, 4.125 vcore at 3.4GHz and 4.625 at 3.5GHz, so yours should not be too far behind. Your memory is better than mine and really should be good enough to go even further, so I don't see what the limitation is. Try another BIOS version perhaps?
what do u mean by 4.125 vcore? or 4.625? could the bios be the problem, and which should i upgrade too then?
any1? whats the best bios for me to overclock my e6400 629b
What is a 629B? Start up CPUz and tell us what revision it says. If it says L2 then you probably won't get much more than 3200 MHz out of it reliably. If it says revision B2 then you should be able to play around with some voltage settings for the memory and northbridge and play around with memory timings and get some more out of this processor as long as your memory doesn't hold you back. Post some more details about your system if you want some more help. What does CoreTemp report when running Orthos and how much cpu voltage does SpeedFan 4.32 or Everest report while loaded.
We need to know voltages for everything. Post anything you can think of.
I'm using the 1215 bios from the Asus website and it works fine. Great overclocking motherboard.
Multiplier is to low. Memory is maxed out.
That is MOST DEFINITELY not it. Its pc-8500 running far below its spec at 400 x 8 (pc-6400). Its got far more room to run that what its at now.
