I recently helped a buddy build a new computer (used for gaming). Everything was working fine for several months up until a couple days ago. He called me yesterday and told me what's happening and, honestly, I'm a bit stumped. I've built comps. before and never had issues, but I just can't tell if it's the mobo or gpu or what.
He said one day the screen suddenly went black, but everything was still working (he could hear sound, etc.). So that problem kind of went away, then suddenly the comp. would shut off. So he'd turn it on, but a few seconds later would shut off again, then turn back on, then turn back off, then turn back on, etc.
He finally got it to turn on, and noticed a black line running through his screen (was never there before). So, he opened up his case to make sure everything was plugged in properly, and noticed the CPU fan was slightly higher on one side, and while trying to put it back in place, it broke (cheap crappy stock Intel CPU fans).
I made sure his mobo's BIOS and GPU drivers were all up to date (which they were). Another friend of ours has the same 9800 GX2 so I was thinking of swapping them and seeing if anything happens, mainly to try and narrow down where the problem's coming from.
Proc.: Intel Quad Core Q9450
GPU: BFG 9800 GX2
Mobo: Gigabyte GA-X48-DQ6
RAM: Corsair 8 GB (4 2GB sticks)
OS: Vista Ultimate 64 (w/SP1+all updates)
Again, what confuses me the most about this is that everything was working fine for a couple months, until just very recently. Thoughts?
GPU: BFG 9800 GX2
