Problem OCing a P4 2.6
hey all!
couple of months ago i got a new computer
the specs are:
Pentium 4 2.6 c 800 FSB
PMI 512 mb Ram 333 Mhz
and a ABIT IC7 MAX3 mobo,
i accedently bought 333mhz Ram in one stick instead of 400 mhz in 2 sticks .
every time i try to OC my computer i cant move over the 2.7 ghz .
is it because the memory?
do i have to change a memory to OC my computer ?
thanks for the answers .
I don't think it is the memory because you would of gotten a higher overclock then 1mhz.
because I had 333mhz 2700 DDRS and got my AMD Athlon 2400 at 2.6ghz.
Try using the 3:2 or 5:4 divider as 1:1 ratio is out of the picture with your ram....you'll certainly hit 3Ghz easily with those dividers i mentioned ealier.....
