Problem OC a A64 3200+ HELP!!!!!
qtqc
Hello everyone, I picked up an ASUS K8N-E Mobo and went right to Oc'ing. I have a Clawhammer 3200+ 64. The only problem is now my OC is slower than my stock speed. Its at 1.16 GHz. When I went back into the bios to load the default, my stock speed is 800mhz. My sisoft sandra is reading the same speed. Anyone have any Ideas whats wrong. Heres some info
SiSoftware Sandra
Processor
Model : AMD Athlon(tm) 64 Processor 3200+
Speed : 1.16GHz
Model Number : 3200 (estimated)
Performance Rating : PR1733 (estimated)
Type : Standard
Package : FC µPGA754
Multiplier : 5/1x
Minimum/Maximum Multiplier : 10/1x / 10/1x
Generation : G8
Name : M4 Athlon 64 (K8 ClawHammer) 130nm 1.4GHz-2.2 1.45-1.55V
Revision/Stepping : 4 / 8 (10A)
Stepping Mask : SH7-C0
Core Voltage Rating : 1.550V
Min/Max Core Voltage : 1.500V / 1.550V
Maximum Physical / Virtual Addressing : 40-bit / 48-bit
Native Page Size : 4kB
Part Number : To Be Filled By O.E.M.
Asset Tag : To Be Filled By O.E.M.
Serial Number : To Be Filled By O.E.M.
Co-Processor (FPU)
Type : Built-in
Processor Cache(s)
Internal Data Cache : 64kB Synchronous Write-Back (2-way, 64 byte line size)
Internal Instruction Cache : 64kB Synchronous Write-Back (2-way, 64 byte line size)
L2 On-board Cache : 1024kB ECC Synchronous Write-Back (16-way, 64 byte line size)
L2 Cache Multiplier : 1/1x (1155MHz)
Upgradeability
Socket/Slot : Socket 754
Upgrade Interface : Socket 754
Supported Speed(s) : 1.16GHz+
Environment Monitor 1
Model : ITE IT8705/12 ISA
Mainboard Specific Support : No
Power Rating(s)
CPU Core Power : 53W (estimated)
Sensors
CPU Temperature : 38.0°C / 100.4°F
Auto Fan Speed Control : No
CPU Fan Speed : 2500rpm
CPU Voltage : 1.65V
Features
FPU - Co-Processor Built-in : Yes
VME - Virtual Mode Extensions : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
CX8 - Compare & Exchange Instruction : Yes
APIC - Local APIC Built-in : Yes
SEP - Fast System Call : Yes
MTRR - Memory Type Range Registers : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
CLF - Cache Line Flush Support : Yes
DS - Debug Trace & EMON Store : No
ACPI - Software Clock Control : No
(W)MMX Technology : Yes
FXSR - Fast Float Save & Restore : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SS - Self Snoop : No
HTT - Hyper-Threading Technology : No
TM - Thermal Monitor : No
PBE - Pending Break Enable : No
IA64 Technology : No
SSE3 Technology : No
MON - Monitor/MWait : No
DSCPL - CPL qualified Debug Store : No
EST - Enhanced SpeedStep Technology : No
TM2 - Thermal Monitor 2 : No
CID - Context ID : No
xTPR - Send Task Priority Messages : No
DAZ - Denormals Are Zero : Yes
Extended Features
SYCR - Extended Fast System Call : Yes
EMMX - Extended MMX Technology : Yes
FXSR - Instructions Optimisation : No
3DNow! Technology : Yes
Extended 3DNow! Technology : Yes
DEP/NX - No-execute Page Protection : Yes
AMD64/EM64T Technology : Yes
Power Management Features
STC - Software Thermal Control : No
TTP - Thermal Trip : Yes
VID - Voltage Control : Yes
FID - Frequency Control : Yes
TS - Thermal Sensor Built-in : Yes
Advanced Settings
System Ack Limit : 1 request(s)
System Victim Limit : 0 request(s)
Extended MTRR Types : Yes
I/O Type Range Registers : Yes
Top of Memory : C0000000 (3072MB)
Machine Check Architecture Settings
Number of Reporting Banks : 5 bank(s)
Exception Reporting Control Support : Yes
