Quick question. I'm using a silverstone case with my MN31N shuttle motherboard. The motherboard tray has raised areas like dimples that fit the board perfectly, but dont I run the risk of shorting the board if i dont use at least a washer or something? If I use standoffs the motherboard wont fit the IO plate correctly and it also causes the DVD drive to hit the memory sticks. Could I use plastic/rubber washers instead? Any ideas would be appreciated.
Thanks,
Dog
Thanks,
Dog
