I got two 10/100 Mbps switches, a 5-port Unex and an uber-cheap 8-port Sweex one.
The Unex switch is part of the original network. It has worked flawlessly so far. The 8-port switch is the new one. It appears to work fine when just connecting random systems to it (w/ static IPs). However, when I use one port on the Unex switch as an uplink port and connect it to the first port on the 8-port switch (which is possible, according to the manual), systems connected to the 8-port switch sometimes can and sometimes can not get an IP from the DHCP-server (connected to the Unex switch.
For example, one system runs Win98 (w/ RTL8139 NIC). It couldn't obtain an IP-address when connected to the 8-port switch, but could if connected directly to the Unex switch. After reinstalling Win98 on this system, it suddenly could obtain an IP-address when connected to either switch. Right now I'm installing SuSE on this system, but it couldn't obtain an IP-address while connected to the 8-port switch.
Other systems connected to the 8-port switch (an HP, P166, RTL8139 and an IBM, PII 300, onboard Intel NIC, both SuSE 9.0) do not appear to have this problem.
Is this just due to a faulty/failing NIC in the Duron system? But then why would it only refuse to work sometimes?
