Hi guys,
I'am trying to setup RAID 0 on my computer, but I'am unable to do so. I have the Asus A8N E motherboard (Note: not the SLI version) This motherboard has just the Nvidia NForce4 RAID controller on it, it does not have the SiliconImage RAID controllers.
What happens is that when I setup the motherboard and the HDD devices to enabled in the BIOS and also the RAID array (by pressing F10 key during boot) to Strip in RAID 0, I'am unable to reinstall windows on the computer.
I have two Seagate 7200 RPMs HDDs (model nos:ST3160827AS ) I plan to use as the RAID 0 drives. After I configure the computer to the above steps and set the computer to boot from the windows XP disk, the computer gives me the message "PRESS ANY KEY TO BOOT FROM THE CD" Then when I do so, i get the following message that "SETUP IS INSPECTING YOUR COMPUTER CONFIGURATION" Then after this point the screen goes blank and the setup does not continue.
I am able to reinstall windows normally without RAID and everything else works fine. No BSODS or anything. It is just that I'am unable to setup RAID on my computer
I have heard that the NVRAID controllers had problems initially, do I need to update the BIOS to fix this????
My system specs are as follows:
AMD Athlon 64 3500
2 GB DDR 400 MHZ RAM
XFX 7800 GTX @ 490 Mhz core and 1.3 Ghz memory
Seagate 160 GB SATA 7200 RPM * 2
Sony 16x DVD RW
Please help me guys, I desperately need help with this issue.
Thanks for everything.
AMD Athlon 64 3500
Sony 16x DVD RW
