problem!!! help
Streamline
idk what is going on, but sense ive had my mobo installed it says im running at -32F/-37 load wtf no way my processor is runnin at -37 degrees is that the senser fucked up? cause im running perfectly fine had no problems w/ p4 2.8E at 1.5V at 3.65 and everything is running great idk wtf is with my sensors tho? maybe a possible mobo problem?
I'd to a Bios update to see if that helps any. What are you using to see those temps? If it's Motherboard Monitor or something you might have the wrong sensor selected.
no im just checking in bios after running for a little while and it says -32 consistant no matter what ive used the program mobo mon. which came w/ my mobo and it shows the same thing, and it also shows all my voltages skyrocketing which is way wrong
Try a bios update, check around to see if other users are having the same problem, otherwise, it's possible the sensor broke, you could RMA it.
Return it to the manufacturer to have it replaced under warranty = RMA.
