Problem......graphics card?
Mc55m
Okay so i built what should be a nice little system for game....
GA-MA770T-UD3P motherboard
Phenom II x4 955 black edition
Asus DirectCu 5850
8Gb DDR3 OCZ RAM (4 sticks of 2Gb)
Antec 850W PSU
3 SATA HDDs 40gb, 250gb and a 1tb
Windows 7 64bit
now, heres my problem, it started with everytime i would try to push the system with a game thats got some decent graphics(COD4, SCII beta, even TitanQuest and now even Civ 4) the screen would flicker a bit then get vertical lines and lock up.....I checked the drivers, uninstalled and reinstalled a couple times to be sure, but is not that. I think theres something wrong with the card, but i want to be sure before i go to Asus to get the card replaced(i passed the 30 days from newegg cuz i lost my job and gave up on trying to game/fix the problem so i could game for a couple weeks). When i first built the system i had a bad stick of RAM and got that replaced. So by then i was already almost 2 weeks into that 30 days so that didnt help......digress....anyway I have gone through so many thing trying to figure out the problem, GPU-Z, 3D Mark, etc, The system crashes when i try to use 3D Mark, i get the lines and it locks up.
any ideas would be awesome!!!
I'm pretty sure that this is a common problem with the 5000 series AMD cards.
Not sure what the resolution is, but I've seen it brought up before. Try searching the forums or google.
Well you might want to pull 2 sticks of ram and see if your still have problems.
Some people experience issues with 4 sticks that can require a little tweaking to get things stable.
