ivan_gromov
- Oct 6, 2006
Hi everyone, any input is very appriciated. Let me fill you in on what I do first.
I started working for ToolKing exactly 2 weeks ago as a full time IT. They have only had 1 real IT before me, and he left about 2 months ago. I am only 18, still in College, and I believe that I am hell of a worker
. Well, there is obviously nobody to train me, nobody really has any idea how pc hardware works, and there is this one guy....who was supposed to be an IT for them, until they have interviewed me. That guy has no degree, he is 25 I believe and he was hired as an Web Developer. When their first IT has quit they kind of tried to force him to be their IT, which did not work out so well.
Anyway, the problem. This lady that I help a bit, her desktop PC has crashed two days ago, I have pinpointed the problem and it is her hard drive. For one, Dell Bios SUCKS, and after 2 hours of working on this pc I was able to get it to see the HDD, but only as a 6gb one. Well, I spoke with the manager and I called up Dell and got them to send us a replacement that should arrive in a day or two. The problem is with the fact that she needs some files from that hard drive.
Dell makes really proprietery motherboards, that PC only supports SATA drives and I do not have any spare SATA drivers at my work, only 1 IDE. Well, 5 hours later, an hour before I was supposed to be getting off that "IT" guy that I have mentioned above comes in and says that the problem is with the fact that there is a virus on that Hard Drive. Me, being their "hardware man" they have asked me to take a look by getting me the same model Dell box from another office to test that hdd. I stuck the broken HDD into that other Dell box and changed the jumpers and the Boot Sequence in BIOS so that the broken HDD is secondary. The dude says that the problem is with the boot sequence, he apperantly did a ton of reseach..... When he was trying to explain the problem to me, he was referring to CMOS and Bios, which has nothing to do with that harddrive and it made me feel as if he does not know wtf he is talking about...
The fuckin system does not even boot with both of the HDD's enabled, It pretty much says that "No Boot Drive has been found". If I disable the Broken HDD via BIos it boots just fine. I did everything I could with no luck. I ended up staying 3 hrs past the 8 hr a day mark trying everything I can. I did research on repairng the Boot Files, the fuckin system just can't read from the drive. I attempted to go through DOS to attempt to fix it, but it simply says that "No Drive has been found". I ran Dell Diagnostics Disc just to see the HDD fail most tests, and it even makes noises when system starts up, kind like the floppy drive. I took it home and spent 2 hours of my 4th of July time trying to get it to boot in my system with no luck...
Long story short, I am 98% sure that the fuckin HDD is a toast and the only solution is replacing it. The fuckin problem is with the fact that this is my first real job and it is actually in the field, I really do not want to look like a moron, I simply do not see anything that I could do to get it to work. I am however worried that that guy can get it fixed somehow, making me look bad.
Aside from the fact that I can bet money to the fact that this POS is broken, what can I do to verify it? The fact that the system won't even boot with that HDD in it is a bit suspicious, but I honsetly think that it is not a problem with the virus. Any recommendations are appriciated.
I tried repairing the Boot.ini via WIn XP Pro installation by going to repair and loading into DOS, but it simply does not see an HDD, I tried a ton of different shit, but I can't do anything since it simply can't read the fuckin thing. HELP before I go insane.
