[PROBLEM] 2007wfp + SLi BFG 6800GT
Gigabit
so here's my dilemma...
Dell 2007wfp + BFG 6800GT SLi
upon boot up and regular websurfing and such, everything works great. The problem arises when i play BF2 (1280x1050) or and resolution with BF2 for the matter. When i exit the game, i get this straight line across the top, greyish in color. You can see pics here:
keep in mind that:
1.) the line only appears when i exit the game
2.) doesnt appear with other games
3.) disappears when i disable SLi
4.) tried the latest Nvidia Drivers including the newer beta's also
What do you think can be causing this and if you have heard of any remedy, i would greatly appreciate your response!!
no, i also have a dell 1704fpt and it doesnt do it on there.
some of the signs and symptoms that i notice doesnt point in the direction that its the monitor b/c it doesnt occur when SLi is disabled nor does it apply when I play Starcraft.
Quiet possibly due to drivers or the BF2 itself.
things that make u go hmm...
i switched over to VGA to test the monitor, apparently the line going across went away with vga.
im still using SLi setup but with an adapter for the monitor cord.
weird.
Is it possible it could be the DVI cable? Can you try another DVI cable?
