Probably not a good idea (considering Eizo CG241W)
Okay..let me make sure I have a few things straight...
1. You won't be using the monitor professionaly (photo work, graphic design etc..)
2. You don't care if gaming isn't good
3. It will basically just be for normal web browsing etc..
Jeez man...first thing you should do is write down the "$2600" on a piece of paper in front of you and then do a little shopping on the web and find out all the things you could get for that kind of scratch. I'm sure you'll find that you're in the realm of 42-46" lcds and 50" 1080p plasma displays. Then ask yourself...is a 24" pure computer monitor worth the same as those?
