1. Setup in low right hand corner
2. Find your desired settings in Data Sources and check them
3. If you can't find them go into Plugins in the lower left hand corner
4. Check desired settings.
5. OK
6. Check the settings you just added from Plugins in Data Sources
7. OK
GG
I think if you look at the fan, it will only have 2 wires, so there won't be speed monitoring. If I recall correctly, the 9800 pro normally didn't have a temperature monitor. I think the 9800 XT did have a monitor, so if you have a pro with an XT core, you might have a chance at getting a successful temperature monitor (I think it was like a RV250 vs RV260 core or something like that). Of course, that was a while ago, so I may be totally wrong here.
/edit: OK, I had to look it up because it was bugging me. It was the RV350 vs. 360 core. But that had nothing to do with it apparently. The XTs started coming with a temp monitoring chip, but some pros did come with it. Check out this: http://www.techpowerup.com/articles/overclocking/vidcard/94
Thanks for taking the time to find that... I have no temp monitoring, oh well. Guess I'll just touch it with my toes and guess the temperatures under stress while I'm playing a game.
