Pro Tools 9 Build
Must:
- have a fast quad core CPU
- 2 HDD, system and audio files (1 SSD would be nice)
- multi mon support (2 or more monitors), passive GPUs is a nice to have
- USB port (for iLok), FireWire is nice to have as a lot of audio equip still uses it.
- whatever interface your audio device needs (PCI might be still required)
- QUIET CASE
Now that the B3 P67 mobos are out I would go with a 2600K CPU.
Here are is a post with LOTS of good info: http://duc.avid.com/showthread.php?t=238426
A standard 7200 RPM drive is fine for Pro Tools. An SSD isn't necessary, and in fact won't be of any particular benefit.
What you need in terms of CPU and RAM is entirely dependent on your typical session size and plugin workload. Can't really answer before that's known.
Phide, a SSD would be nice because it is one less thing making noise.
Also I agree with you in terms of how big his sessions are going to be, but my recommendations are based on his budget.
He is going to need a HDD for storage anyway so noise is a moot point. A HDD mounted properly in a decent case barely makes any noise anyway. Like Phide said, session size is essential.
Answering these questions helps.
http://hardforum.com/showthread.php?t=1349433
