Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I plan to overclock my 2400-m to atleast 2.5 ghz. I was wondering if my pro core could handle the overclock aswell as watercooling my gpu and northbridge
Yeah, that radiator should work just fine for you. Make sure you have a shroud with it. And a powerful pump if you're going to be cooling all 3 of those.
Yeah it'll be fine. I had 3 blocks in my loop but took teh NB out. It didn't do much other than kill my head flow a bit. I get the same OC without it too.
