GotNoRice
- Jul 11, 2001
I'm using an old Core2Duo box to build a pfSense router for a friend. The plan was to install a Pro/1000 PT Dual-Port Server Adapter (4x PCIe card) into the empty 16x PCIe slot but for whatever reason the system won't boot when the card is installed.
The motherboard also has 2 regular PCI slots. I have several Pro/1000 XT Server adapters (PCI-X cards that also work in regular 32-bit PCI slots). The system boots fine when they are installed. They are from ~2001 however. Any issues using cards this old for pfSense? Would there be any noticeable drawbacks compared to if the much newer Dual-Port PT Server Adapter had worked?
Connection is 300Mbps down, 20Mbps up.
