Private network setup for a work project needed(Ethernet to fiber.
Headbust
Hey guys, I have a little project at work that involves converting the following comma path to get the end result I need.
The conversion path goes as follows..
Server
NIC Card 1 DHCP (company network)
10.40.xx.xxx
255.255.255.0
NIC Card 2 - STATIC (private network)
10.10.10.10
255.255.248.0
Ethernet to Fiber - What IP to route through 10.10.10.10 on NIC2?
Fiber to Ethernet - What IP to communicate with the one above?
NIC2 we use as a backdoor in case NIC1 fails or the coma by network is down, that's why we set it to 10.xx.
I think I am close to getting it working but no luck so far. NIC1 has a gateway since it's DHCP but NIC2 Does not have this option. The Ethernet to fiber converters also request the default gateway but as I mentioned NIC2 is not able to be setup with one. Do I use the one on NIC1 or am I way off?
Any help appreciated!
