Mar 13, 2008 #1 B brisk Limp Gawd Joined Aug 5, 2004 Messages 219 Hey Just wondering, can I use the USB port and the network port both at the same time? As in one computer is connected to the USB while the network port is connected to a different network? Thanks.
Mar 13, 2008 #2 zoobaby Supreme [H]ardness Joined Jun 7, 2004 Messages 6,179 Should be able to. What printer? If HP, I can pretty much say yes they both are active at same time.
Mar 17, 2008 #3 B brisk Limp Gawd Joined Aug 5, 2004 Messages 219 Ok. Because after calling HP they said that it would mess up my drivers and what not and I can not do it. So this is good to go? Thank you in advance.
