Printer Problems? Weird...
fusionrs
Alright two of my friends have HP printers. I do not know the specific model number but here is the problem. When they press print on their machines it will send it to the printer and start printing it backwards. Like last page first kinda deal. It takes a awful long time for it to print. I tried another computer using the same drivers and it printed fine first page...second page...and so on. There are no Viruses, Spyware, ect. I cleaned the computer before trying again. I have also unistalled the driver and device and reinstalling. Any clue what is up? Thanks...
check your printer settings. not knowing what model does not help. see if under your advanced tab you can change the print spooling optioins. you could be overloading the printers memory if you are sending the entire job at once.
other than that it could be your bidirectional settings are wrong, but I am suspecting since you are printing in what is called a N-1 order that iis the culprit.
