Printer power consumption
the-one1
I have an old Apple Laserwriter Select 360 fro free from work and I just fround out how much power it uses, I got the following specs online:
# LaserWriter 16/600 PS 790W
# LaserWriter Select 360 450W
Anybody got anyinfo on a standyby mode for it?
It is most definately not going to draw that much power constantly(unless you are printing constantly). It is only going to draw that much when you are printing and everything is turned on. If it is an older printer then chances are it won't have any kind of power-saving mode other than turning it off. That's not to say it's going to be drawing a lot of power when it is on, though. If it is on and just sitting there then it probably won't be drawing much power at all.
