printer ink dried up or dead printer?
polive
I have a Lexmark Z605 inkjet I've had a couple years. Only gone through a couple ink cartridges. Last time I changed the cartridges was probably 6 months ago.
Barely used the printer since then, a couple times here and there. Last week I go to print a web page and it shows basically nothing. Ran the clean utiility on the driver a couple times. It shows very weak to no ink on the page. Doesn't matter whether I'm printing black or color, almost no ink output.
Do these cartridges dry up and become useless over time? The price of new cartridges is about the same as a new frickin printer! Think I should just buy a new one? Maybe a laser printer...
I have had the same type of experiences with a Cannon inkjet at work. We have a printer that rarely gets used and when it does, we almost always have to install a new cartridge.
Lazers are nice, but you can buy one or two inkjet printers, with ink, for the cost of a toner cartride for most lazer printers. On the other hand, toner cartridges last a long time, so it really depends on how you'll be using it....
I bought an HL-1440 for school back in 2003 for ~$180, and I've had it ever since. If you aren't printing in color very often, but print in black and white, laser is the ONLY way to go. It is SO much cheaper in the long run it's unbelievable. A high capacity toner cartridge lasts for 6000 pages, and the quality is consistent, flawless, and quick. The toner carts are certainly more expensive at $60 shipped ($30 for the "compatible" carts) for the high capacity, but because it prints so many pages it boils down to 1c per page (or a half cent per page if you're using a "compatible" cart).
To pick one of the cheaper inkjet printers often found on the UW campus as an example (Epson Stylus C40), their $15 black ink carts only produce 210 pages, which boils down to an expensive $.072 per page. Your Lexmark seem particularly poor at over $.09 per page. This isn't isolated to these printers; it's a phenomenon that applies to all inexpensive inkjets.
I'm sure there are newer and less expensive lasers (with cheaper carts) out there that do just as good a job as my HL-1440, so if you do your research you'll come up with some awesome deals. Just thought I'd make sure you knew that the laser option is one many people should look into.
EDIT: forget to mention that yes, inkjets are affected by disuse. even humidity can mar their printing quality.
Basically the nozzels are clogged on the print head. Try rubbing the print head with a bit of alcohol and a clean cloth/paper towel.
They can dry out if not used enough, try printing a single page once every couple weeks to prevent this from happening again.
Thanks for the replies and advice. And out with this printer!
