Printer I need....
icamp31
Here is what I need, does anyone have suggestions
I need an affordable laser printer to print envelopes, I want a tray that will hold and feed a lot of envelopes as that's what I mostly print, I have a Samsung with a manual feed and it's ridiculous to sit here and print 30 envelopes one at a time.
So anyone have a suggestion? This feature doesn't seem to be well documented for printers they merely say it's does envelopes of whatever size but no tray capaicity or multiple feed specifications
I have a hp laserjet 1020 that rocks for the price. Not sure if it has a specific letter slot but I can check tomorrow. It is at parents house.
thanks if it can hold multiple envelopes i nthe tray instead of 1 envelope at a time it would work
it is only 130 or less in stores if you want also.
I don't have any evelopes I need to print en masse so I can't try it for you but one works great. The top tray is for single feed and the bottom tray shows a icon for envelopes and a stack of them and instructs you to move the guides closer for envelopes. I am pretty sure it would work for your needs. Warms up in less than 2 seconds even.
