printer help
;lksajdf;alkdsjf I replied to this yesterday, but I guess it never went through, hehe.
I don't see your printer listed in supported devices. aAlso, thats a bluetooth adapter, so be sure your system supports it. if you want a wifi adapter, you'll need something else (newegg has several, too lazy to look again).
Have you looked at reviews for the device; not sure how well it works.
An alternative solution is if you have set up your printer near your router, and the printer is USB, you can buy a printer server ($10-$30 depending on sale). You will connect printer USB to printer server, and printer server connects via Ethernet to your router, then you can technically printer wirelessly.
