Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Try different software and see if you get the same results. If you are using windows98 or 2000/NT you could try "Imaging" - you could also you windowsXP's photo printing program.
If I had problems with accuracy, i'd use draft paper and adjust the image size in the print out until I get what I want.
