I just setup a print server and everything seems to be running fine. I can print from one computer only though. The second computer I'm trying to setup doesn't want to use it. It is pingable from the other computer, when I goto add network printer and I browse for one, it sees the printserver and the printer, but it says the printer name is invalid or the print server has lost contact. If I try to set it up as a local TCP/IP port, it sets up, but then later says that it cannot install the printer driver when I tell it to. I'm trying it on a third computer now, will report back.
EDIT: Same thing with the third computer. Its name is \\printserver\canonpixma170, is that a bad way to name it?
