- Dec 2, 2009
Ok so i was running a torture test on my cpu with prime95 (the middle one that test some memory) and before the first test was over, 3 of the workers failed.
i then reset the test to the one that uses the least amount of memory tested and so far, the test has been running for 25 minutes with no fail, so im assuming my memory is what caused the test to fail.
i downloaded memtest86 but wasnt sure how to use it. please help!!
Edit***
ok figured out memtest.. the test failed but it does not specify where it failed (which those of you who are not nubs would know =D)
So now this is my questions:
what should i fix considering i havent done anything to the ram (i.e. overclock) and all the settings are factory matched
ALSO
my core is OC to 3.0 Ghz. after 25 min of torture test, temps were pretty solid at 48-50C
are those good? and if i go to 3.8 what temps would be ok for me to see? also will i damage the core by running it at 3.8 if its properly cooled (i.e. will its life span decrease and by how much?)
Edit***
ALSO
