unfortunateson
- Jul 17, 2004
For some reason, Prime95 now will not max out the CPU usage in the task manager on both cores. I have two instances, both set to separate affinities, but the task manager shows only 56% cpu usage, the first core is fully loaded and the second one barely is reading. If I start the first instance stressing the second core, then the first core barely reads.
Could this have anything to do with the AMD dualcore drivers? Any help is appreciated.
