I recently finished my new system, and since I had plans to overclock, I decided to do some testing with Prime95 before making any changes. I ran one instance with Small FFT's and another with Blend. In less than 8 hours, Blend failed...
Here are my basic specs:
Opteron 170 (with stock fan)
ASUS A8N-SLI Premium
eVGA GeForce 7800GT
1 Gig Corsair DDR400
Antec TPII-550
CPU temperature never exceeded 45 degrees, the whole time. Voltages were all normal, as well. Previous runs of memtest showed no memory problems.
Should I give up on the overclock before I even get started? Should I be thinking about returning the processor? Should I run more tests? Any help is appreciated.
Code:
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 7 hours, 56 minutes - 1 errors, 0 warnings.
Execution halted.
eVGA GeForce 7800GT
Antec TPII-550
