Well, as the thread title says, I constantly get an error in SP2004 and Prime95. They tend to run between 45 minutes to 2 hours, and then I get something like "Self-test 896K passed!
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file." Is this normal for an E6600 that isn't overclocked at all? It's running around 32C, but I can't get the motherboard to run cooler than 45C or so. is this likely a problem with the CPU, RAM, or mobo? I don't know how long the warranties will last, and I'd like to overclock, but if I'm getting errors without OCing I'm kind of worried. The system itself "seems" stable, though it did randomly reboot twice, and I have no clue why. Anyone have advice on any other tests I can run to narrow down problems, or anything to look for? Thanks
