Prime95 Error
99TurboEx
Does anyone know what this error message means ?
FATAL ERROR: Rounding was 0.5, expected less then 0.4
I get this message as soon as i start the torture test
I have a P4 3.2E Prescott @ 3.68, Cpu temp stays below 60C under load.
Kingston Hyper X memory DDR500, or DDR 400 Can't remember
Nvidia 6800GT @ 401 and 1101
the mother board is an Abit IC7 with the lastest bios update.
I been running the computer at these speeds for a while now, and its stable (No crashes or lock-ups).... I play games like DOOM 3, Counter-Strike Source, Far Cry for hours with no problems.
it means either your ram or processor, or motherboard isn't as stable as some may like (I am one of those 24/12 hour primers).
Up your VDIMM or CPU voltage. VDIMM if it fails memtest86 (which you should run). CPU voltage otherwise. If this doesnt help, lower your OC.
Nailed it on the head.
Ok, I upped the Cpu Voltage that didn't do anything ... where can I download memtest at? ......also in my bios i can up the voltage for DDRvcc .. and thats not doing anything .... using Abit EQ theres also DDRvtt but i can't figure out how to increase the voltage for that one ?
