Prime95 and Orthos
mtanc
Hi,
Is anyone using either Prime95 or Orthos with Vista? If so, I would like to know where I can get it. I can run TAT with Vista, but still looking for the others that will go.
Thanks,
Mike
shmitty,
Thanks. I went to the site and d/l'ed, ran it, it crashed after monitoring in ten seconds. I then raised my vcore up a notch, and it ran for two minutes and crashed. I then set it to just test the cpu, and it went the distance. It seems like a good program, but I have to figure out how to use it.
I go to the tools icon and it seems all preset and I can't figure how to get readings for the coretemps, voltages, etc. Everything is blank and I can't get any options. When I click on the monitoring tab in the tools section, can't seem to change anything there. It's all blank.
I think this thing (once I figure it out) will be at least a great program to run after each tweak because it only takes 30 min. It seems as though it will pick up on errors quickly, so if you get to a point where you think you've gone far enough, then if it still says you are stable, you can then run orthos, or prime, or TAT for a long period and see what happens.
Good program.
If you are real familiar with it, and have any thoughts or suggestions on how to configure this thing, let me know.
Thanks,
Mike
