I haven't had any stability problems with my compuer running games and whatnot, but decided to try out Prim95 64-bit to see what the temps got up to. I had been using Orthos in the past.
Whenever I run Prime 95 64-bit it errors out on one of the cores after the first step of the test, If I let it keep going, it reboots the machine.
Temps are only getting up to 61C and changing settings in BIOS.. voltages, etc. doesn't help.
Anybody know if Prime 95 25.7 or even specifically the 64-bit version has issues.. maybe with Vista only?
