Prime85 and voltage
Aerobahn
ok quick question. If i get an error in prime95 that means my Overclock isnt stable right? After upping my voltage 0.063 the errors are gone Load temps are 36C. Am I understanding this right or are the errors in prime 95 something different. 0.063 isnt too much extra voltage i assume so i have room to go up a little more correct?
You have everything right. You could up the voltage more if you overclock more and get errors, but as your probably noticed as you up your voltage your temps will rise. What CPU/mobo/RAM are you using?
P4 2.8c @ 3.4 +0.068 volts
Gigabyte 9800 pro @ 455/357
GA-8IK1100 mobo
1gig GEil 3200 ram
CPU + gpu water cooled
still trying to get more out of the cpu while staying under 39c
