sladesurfer
- Feb 4, 2006
What does it mean when you're burning a cpu and one core fails but the rest of the core will burn for hours. Is it a failed Overclock?
Memory can also cause prime95 to fail, particularly if you have it set to use a lot of RAM (which is best IMO if you really want to test your system, not just the CPU).
