chuckm1020
- Jun 12, 2003
k this is weird. if i do a torture test on prime 95, i did the maxiumum heat, maximum power, and some ram tested. then i start the test i hear a high pitched chearping noise come from my computer. i took the side off and im pretty sure its coming from the psu. if i stop the test the sound will stop, then when i start it again the noise will continue. then i noticed when my comp is at idle i go into cpu-z. the v-core wich i have set at 1.9V is going between 1.85 and 1.9. its never stable. is this a bad psu. its an Antec 550W truecontrol
