Prime 95 questions
jagzzzzzz said:
What setting should I run prime 95 on? Torture test, but which one?
Launch ya Prime 95, then Menu Options > Torture Test > In-place large FFTs.
This sort of test will stress your CPU the most. I often use this way to stress my CPU. Let's see others' ideas.
And an error about 30 minutes into it, means it is unstable, correct. I have my Vcore at 1.7 which I do not want to go any higher even though I am WC and the temps are great. I can mess around with some of my other settings, but I am trying to stay at a 1:1 divider. My memV is 2.8. Any ideas?
