system is athlon 64 3200 @ 240 X 10 CPU voltage 1.45
1gb OCZ plat rev 2 3200 ram 2T disabled everything else auto
asus a8v rev 2 1008 bios
BFG 6800 GT OC
74gb WD HD - on promise controller
250gb WD HD - on promise controller
NEC 3500a firmware 1.17
Enermax 485W PSU dual 12v rails supplying 18A on each rail
Bare minimum fan cooling - stock cpu fan and 4 case fans
Question been trying to OC this system -
At 250X10 i get prime95 rounding error within a 5 minutes
at 240X10 i get prime 95 rounding error at 29 hours 45 minutes
Since it has run past 24 hours would people consider the system stable?
I've read the FAQs on OCing but am still confused about what mem setting I should run
My 3rdmark05 at 1024X768 was 4777 - is this respectable I see guys getting high 6000 or low 7000. Is this possible with just fan cooling?
BFG 6800 GT OC
