elm669
- Jul 8, 2003
For about the last 5 months prime95 has ran fine on my computer with a max temp of 46C @ 70F ambient then during the summer 56C @ 90F ambient. Only in the last month have I been having temperture problems like hitting 60C while running prime95 Which I though I fixed by tightening down the zalman that was coming loose. It brought the temp down to 54C. Well now it does this:
As you can see from the pic it fails every 48 minutes at the same one with the same rounding error yet I can play doom3 for hours and get the temp over 50C and it won't give me any errors. To top it off it's the same copy of prime95 that was working fine for months. Other than prime95 failing I notice no difference in the performance of the computer nor have any issues encoding images, mp3s, etc..
Prime95 fluke or hardware issue?
I'm off to test the ram and and redownload a new copy of prime95 to test some more.
