Primary IDE channel: No 80 conductor cable installed
That's an error message I get when turning on my PC, afterwards, everything works fine. But error messages annoy me !
Especially when they make no sense like this one (I believe my ATA66 cable is an 80 conductor cable). Also, this only happens when I have my DVD drive connected as primary slave (with my harddisk being primary master).
So, what can I do ?
It's not an error, it's just being nice and telling you. If you don't like it install a 40 condutor cable.
I had the same problem on a soyo board, and I couldn't find a way to turn it off.
You need ATA100 cables for both, one of the ones that you are using is the older, ATA33 cable. You can tell by the density of the wires. Get a new cable.
Sounds like a new bios is in order. See if there is an update at the manufacturers website.
No, it's the cable. My A7N8X does it too if I don't have the new, high-density cables installed.
