Price Drops @ Monarch
i think i'm going to buy the 4600 for $250. should i get the manchester or windsor?
They actually raised prices. They lowered prices 4 days ago, they are now UP.
AMD Athlon 64 X2 4800+ Dual-Core 1MB Per Core 90nm (939) (Retail Box-w-Fan)
Code: 120243
Price: $345.00
Quantity in Basket: none
This was 320 dollars just yesterday and was for a couple days.
I actually had money saved for this, but my mom spent it all. I was going to get this CPU for 320 dollars. Now I am pissed off.
I'm waiting until more stores do the drop and see if someone beats the early bird price droppers. ;)
I still say wait. They will only get cheaper in the next couple of days, especially with conroe's launch coming up and with more places lowering their prices.
or sell out :cool:
Code: 120243
Price: $345.00
I'm somehow not shocked at all over this. I mentioned in another thread that this was probably going to happen with all the 1MB per L2 939 CPUs that were being discontinued. Hopefully this doesn't become widespread across all the vendors!
Meh...the only one I would go for is the X2 4200+ but $200 is not low enough to stop me from going Conroe.
So if you OC these chips, is there much of a difference between the 3800+ and the 4200+?
If you don't OC, is there much difference then?
There's virtually no difference in the 3800 and the 4200. Just clock speed. They both should OC just about as far as each other.
Great. Time to sell my old CPU.
Thats a hell of a deal on the 939 4400 and 4800 (2x1mb cache cpus!) A week ago they cost twice that :)
someone correct me if im wrong, but isnt the manchester for socket 939 and the windsor for socket am2. so for you, you would have to get the one compatible with your motherboard, assuming you already have a motherboard for this. If you dont have a motherboard, i would go with the windsor because socket am2 is a later, more updated socket. Am2 socket motherboards use ddr2 while 939's still use ddr memory. for processor performance, i dont think there is much of a difference. hope this is correct and hope it helps.
yep you're right
Monarch had the X2 5000 for ~289 (OEM) for a few days and now its up to 335 AND oos...damn
