memnoch_thedevil
- Jun 3, 2008
I decided to stay at 3.6 for now, until I finish my case, even though I got 4.0 stable finally, the extra volts and heat (load in the high 70's vs low 60's) aren't worth it right now.
I reloaded my saved profile in the bios, added my storage drive, and plugged in my two printers via USB, my speakers, and digital optical for my stero in the living room, and the 2nd dvi cable for the tv in the living room. Booted up fine, then started to install all my programs again. Installed everest, and it installed fine, but as soon as it went to open and scan everything, I got bsod. Same thing twice in a row. So I went back into the bios after I reset the CMOS, and manually put in all my settings. Booted back into Windows, and Everest does the same thing. So I tried some other programs. Some installed fine, others would hang, and I would have to open task manager, and close it down that way.
I gave up and went to bed, and reran P95 to check stability again, and well it's fine.
So is it something I plugged in? How do I fix this? Let me know what info you might need.
Thanks!
Thanks!
