At work we have a document that is currently fully restricted on the network (no one but system admin and maybe some of the upper management can even get to the folder the file is in). The only way for us lowly peons to see the contents is to use the hard copy that is printed out and kept track of by the managers. This is highly inefficient because the document is something like 150 pages long and searching through by hand for a specific name/whatever is impractical.
At first I thought there was a way we could prevent the copying of the file that management fears so much by setting it to read only. I learned that this does not prevent copying by way of save as or print screen.
Our first intention was to set up folder permissions to only allow people who would need to use the document (the engineers and managers) to gain access to it. On top of that adding logging to the folder to see who/when someone has accessed it.
My questions are these:
From my research it doesn't seem like the last three are possible, but I thought it couldn't hurt to ask!
The real goal is to prevent any duplication of this document both for revision control and protection of proprietary information from being stolen. If this isn't possible I guess we're stuck with the good old papyrus copy that we have to sign out from our managers desk (I'm serious about the latter part)
Thank you for any help!
- Justin
- Does logging show if someone did a copy paste, a save as, or a print screen on the file?
- Is it possible to disable copy-paste in a folder?
- Is it possible to disable save as on a file?
- Is it possible to disable print screen in certain files or file types only? (We use print screen on CAD packages to take quick screen shots of concepts so it needs to be enabled)
- Justin
