Strange bird
- Feb 19, 2021
Does anyone know where to get these sponges for Presonus HD7 headphones? They started to fall apart, probably from old age and sweat.
The diameter is about 82-85 mm and the thickness is about 2 mm.
The sponge doesn't have to be original, it would be good if I could cut out something that works as a replacement.
As far as I can see, they are not glued (or they were and then they came off) to the driver, but they just slide under the ear pads and that's it.
Right below them is a bare naked driver.
