just after some heat info
my prescott 3.4ghz runs at like 50-62c at max load stock lga775 cooling
clocked at just under 3.8 seems to max out at 67c under load but i didnt test it very intensively as i was worried with the temp that high
is this to hot for a prescott? how high can they go without damage?
note: room temp is usually about 25c
a friend told me that you can get a bracket to stick a zalman7000 on the lga775 chipset anyone know if these work well? (the bracket that is)
thanks in advance
thanks in advance
