I just hooked up a computer, tested it out, not totally done yet, the case was giving me trouble. But with only CDrom and floppy left to put in, i decided to make sure everything else worked. System booted, I went into BIOS, first thing I went to was the temps since it was a prescott I had to check them out. It started off at 52C then RAPIDLY increased up to 70C then stoped for alittle and when it hit 71.5C I decided that was to hot, and turn it off. That temperature would FRY most P4s, but is this a normal temp for stock heatsink? I know they run hot, but making sure this isnt to hot. Im going to make sure the heatsink is positioned right tommorrow when I get home, and finish the work.
