pashonic2nd
- Aug 3, 2002
I thought would be an important topic to talk about. After reading a view articles and doing a few testing myself I have found that the Prescott E0 is dramatically superior when it comes to Overclocking over the previous Prescott version, the D0.
I recently bought a 3.0E E0, without knowing it was an E0. I decided to test its OCing abilities by starting the FSB at 200 and increment it by 1 each time and run prime95 for 30mins to see if there are any errors. SO FAR I am at 238 FSB (3.57GHZ) and havent had any errors to speak of nor did I have to raise the vcore a single notch. Pretty cool!!!
Ill keep this thread updated as I increase the FSB further. You can check out my cooling system here .
http://www.hardforum.com/showthread.php?t=846594
At default voltage the chip is running 54c on full load and that is without compensating for ABITS over temperature readings.
Here are a few articles I found about the difference between the D0 and E0.
http://www.xbitlabs.com/articles/cpu/display/pentium4-570.html
http://www.behardware.com/articles/532/page1.html
